1.6 lifters - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2002, 05:48 PM
New Member
Post 1.6 lifters
On a mostly stock 300 hp 350, If you change the rockers to a 1.6 lift, how much will that affect the cam duration ? Should I be aware of any problems doing this. Existing cam lift is quite low (.39/.42 and duration is 198/212). Thanks
Old 04-17-2002, 07:18 PM
Tom Tom is offline
Post
It won't effect the duration at all just the lift
Old 04-18-2002, 06:19 AM
Phat's Avatar
Toy builder
Post
Have found on the stock stuff..try just the intakes first.(half a set) You do need to check the rocker geometry its not just a bolt on deal.
Old 04-18-2002, 02:38 PM
New Member
Post
Thanks for the info, I will try the intake first. Bud
Old 04-19-2002, 06:48 PM
Post
I put a set of 1.6 roller rockers on a fairly stock 300 hp 350 and it worked just fine. It seemed to rap quicker and smoother.
I don't believe you will have any problems or regrets with this modification on a mild 350.
Old 04-20-2002, 08:45 PM
Post
Check your geometry, by putting some bluing ink on the rocker and turning the engine over ( probably by hand) so that the valvles ( intake and exhaust) both open and close completely. Then take the rocker off again and check to see where the rocker is riding . If it isnt close to center you will be hard on the valve giudes. I would also check that the springs arent binding when the valves are completely opened . In your case you are likely all right , but for what little time it takes, check it out anyway. Better safe than sorry! Hope this helps.
Old 04-24-2002, 06:40 PM
F-1Rodder's Avatar
Post
I don't know what your objective are, but I think I would go for a bigger cam first. It would cost you about the same or less and you would get modern cam design working for you.
« vw engine | help »
