1.6 rockers - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2007, 08:16 PM
1.6 rockers
I,m currently running performer rpm heads 64 chambers with 170cc runners 1.5 rockers. The matching cam has at .50 234/244 with .488/.510 lift. My question will 1.6 rockers give me any more horsepower or should I keep saving for those pro 1 dart or AFR heads. thanks for any help.
Old 10-12-2007, 08:50 PM
dawg's Avatar
NAVY VETERAN
yes they will
I used 1:65s on the intake side
but they wont give you a real lot of horsepower
Old 10-12-2007, 10:02 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Be sure to check if you will not have spring bind using a 1.6 ratio, verses a 1.5 ratio. I had that once, and had to use high-rev lifters and change my gear ratio, to compensate.
Old 10-13-2007, 06:33 AM
Notorious's Avatar
Hot rodder, not street rodder!
The gain will vary by application of course, but I know on a stock LT1 that a switch to 1.6 rockers and LT4 springs is good for an honest 12-15 HP. It increases lift by around .030"~. And as carsavvy stated, make sure your springs can handle it. As well as checking for coil bind, make sure it won't exceed the overall lift recommendations for your current springs either. You'll need to know the current installed height to compute that.
Considering 1.6 rockers 302 Z28 Engine 3 07-25-2006 06:04 AM
1.5 vs 1.6 roller rockers? Streetmaster Engine 10 09-09-2005 10:27 PM
Can I use 1.6 ratio roller tip rockers? Houman SS '70 Engine 53 05-13-2005 01:04 PM
1.5 vs 1.6 rocker's bowtieorbust Engine 1 03-13-2004 07:53 PM
1.6 rockers vs 1.5 rockers michhotrod Engine 4 05-10-2002 10:12 AM
