#1
1.7 vs 1.8 rockers
Hi engine guru's. My ZZ502 crate engine came with stamped steel rockers (1.7 ratio). Is there enough piston / valve clearance to go to a 1.8 ratio roller rocker? Would I have to change pushrods? Would I gain enough performance to make it worthwhile or stick with the 1.7?
Thanks
Register now (free) or login to remove ads |
#2
There is enough difference in tolerance stack ups from engine to engine that this is best measured for the specific engine. Generally there isn't a problem, but given the cost of fixing a parts collision I wouldn't hang my hat on that. One of those things where the probability is low but the consequence high on a risk chart. Bogie |
#3
^^^^The change wouldn't be enough to matter keep the 1.7 JMO
Cole
| Thread Tools | Search this Thread |
| Similar Threads for: "1.7 vs 1.8 rockers" | ||||
| any difference when adjusting roller rockers over stock rockers, using self aligning? | redfish211 | Engine | 1 | 10-12-2011 03:12 PM |
| Shaft mount rockers VS stud rockers? | Stonebrier 2 | Engine | 2 | 06-07-2010 05:40 PM |
| roller rockers and cam VS. standard cam and rockers | slipfreak84 | Engine | 5 | 09-30-2008 10:55 PM |
| standard rockers vs. roller tip rockers | andybird | Engine | 6 | 02-27-2003 12:18 PM |
