-   -   1/8 & 1/4 mile estimates (http://www.hotrodders.com/forum/1-8-1-4-mile-estimates-36722.html)
showtime69 03-26-2004 10:00 PM
Hey guys just wondering what times i should run with my 3100 lb first gen camaro.. i have turbo 350 and 411 gears.. I have 3000 stall and drag radials.. Heres what my motor puts down @ the crank
max hp - 511
max tq - 485
With 150 shot
max hp- 661
max tq -692
Please post ur 1/8 and 1/4mile estimates for both N/A and nitrous setup.. Thanks u
badknuckles 03-26-2004 10:04 PM
1/8- fast
1/4 fast
that is my estimate. with nos my estimate changes to faster.
seriously you will be in 11's or even 10's.
onecoomofo 03-26-2004 10:04 PM
What size motor? also what all is done to the motor and what accessories are on it. That would help me narrow it down.
Also, are those real HP and TQ numbers from the dyno, or a computer program?
badknuckles 03-26-2004 10:06 PM
if that is a computer dyno i wouldnt trust it.
i have seen a computer dyno miss by over 100 hp.
showtime69 03-26-2004 10:20 PM
Chevy 355 cid
Im running holly 750, victor jr intake, canfield 200cc aluminum cylinder heads w/ upgraded roller springs, custom grind roller cam 238/244 duration - .580/.585 lift, Im running no mufflers , just headers , to straight pipe. I have a turbo 350 w/ harden sprag gears , 12 bolt rear end w/ mosier axles, 4:11 gears, Frame ties, Traction bars, and BFgoodrich drag radials.... I got these crank power ratings from desktop dyno , which i hear is extreamly accurate! Like i said im running my 69 camaro which weighs around 3100 lbs... Alright with all that said, Lay it on my boyz
badknuckles 03-26-2004 10:24 PM
sounds like a good setup. i dont trust cpu dyno's all that much.
showtime69 03-26-2004 10:26 PM
Any guesses on the times?
badknuckles 03-26-2004 10:27 PM
say those hp figures are close. you should be running mid 10's-mid 11's
showtime69 03-27-2004 12:29 AM
any one else ??? I really wanna know what im going to be running this year.. I figured mid 11's with a 150 shot.
killerformula 03-27-2004 02:50 AM
Your estimates are about 50-60 hp high I think. You'll be in the 12's.
K
showtime69 03-27-2004 11:57 AM
Did u say 12's?? I really hope u mean 12's all motor?? I should deff be in the 11's with a 150shot. My car only weighs 3100lbs!
killerformula 03-27-2004 11:58 AM
yup, that's what I meant.
K
BLOWN 1100 03-27-2004 09:20 PM
Only one way to know, the clocks don't lie
singletoncamaro69 03-27-2004 09:43 PM
I'd check that wieght again my 69 is very similar setup ( weight wise) and it is at 3480 but I still say 11"s with NOS for sure!:thumbup:
Rhansen 04-02-2005 07:39 PM
My motor only made 87% of what DD2000 claimed it would.
