1.94 vs 2.02 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2007, 01:08 PM
fbodyfreak's Avatar
Who loves burnt rubber
1.94 vs 2.02
can any one give me an estimate on power to be gained by putting a set of 2.02 heads vs 1.94
Old 02-02-2007, 01:10 PM
MI2600's Avatar
Member# 3287
My machinist claims you won't know the difference in the seat of your pants.
Old 02-02-2007, 01:33 PM
fbodyfreak's Avatar
I have read the other posts that say you get better torque in the low end with the smaller i am running a stock tune port with a small cam and headers is it worth the trouble to change the heads. both sets are 76cc chambers and i have 2,5cc domes on the pistons if it makes a difference
Old 02-02-2007, 01:43 PM
327NUT's Avatar
If you have a daily driver you'll never see the difference. Not worth the money or time involved.
poncho62's Avatar
Wiki Edits: 5
I've been told that on a street car, its not worth the cost to go from 1.94s to 2.02s.........Maybe, with open headers, it might make a bit of difference.
Old 02-02-2007, 04:57 PM
Steve karch's Avatar
In a mild street engine 1.94 are fine. If your running a high horse power engine at high rpm then 2.02 are good.
Old 02-02-2007, 07:57 PM
the bigger valves are only a benefit on a large cube small block or a smaller small block at very high rpm. you can make 400+ HP with 1.94 heads easily. several years ago i built a 350 with the keith black mini dome pistons. .110 dome if i remember right. 1.94 truck heads 76cc chambers. very mild port job. rpm intake. this motor i put into a 77 camaro with 4:10 gears and a 3500 converter. it ran in the 11.30's in very good air, 11.50's in summer. so it made good power. ive put together similar engines with 2.02 valves with similar results. remember that unless you have a larger bore, you reach a point where the valves are beginning to be shrouded. so the benefit of the larger valves is diminished. on a 400 plus cube small block intended for racing, larger valves are the way to go, even larger than 2.02. but for a 400 hp or so 350 or 383 thats a street or street strip motor, spend your money somewhere else. as someone else mentioned the smaller valves will also give you a more responsive motor down low. but since you say you have both sets of heads already, try the smaller valve heads, if you arent satisfied, try the 2'02's. and dont forget to post the results. try to get a few dragstrip runs in hopefully similar conditions if possible.
Old 02-03-2007, 01:42 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
JMO
We're talking performance here, not grandma rebuild.
Let's say installing a bigger valve into the same head, so we have a level playing field, ok. Just gouging it out and putting in a bigger valve is not worth the trouble. So I sort of agree.
The valve is not shrouded all the way around.
and it depends on the chamber shape.
Shrouding is irrelavent at lower power demand since the open valve flows way more than the engine demands anyway.
.040 more valve is not that much more to ruin shrouding. Gains come by the usual throat cut under the valve and the deshrouding in the chamber which should always done when any new valves are installed. Even if they are the original size (most machine shops are afraid to ask for $40 more to do it right.) Hand blending is recommended on intake and exhaust bowls, more $.
Adding a bigger valve is like "A bigger door lets in more wind." A 4% larger diameter valve is a significant amount of opening increase, which is in effect as soon as the valve moves off the seat. 4% larger circumference on a valve that is only open .100 is a large increase. .200 is less, etc, at .500 is not all that much. You are increasing the total flow area, percentage wise, a lot more at lower lifts.
Remember air is elastic and has momentum. Starting more air moving sooner with a bigger valve allows more air into the cylinder all the way through the intake stroke.
Yes they will make more power. Maybe 4% at lower rpm, apples to apples. With a proper throat cut, deshrouding, and blending maybe 8%. On the average 350 cubes, probably 20 torque and 20 hp.
Will you notice it in normal driving?
I would only do it if I needed new valves anyway. I would not go out of my way to do it unless I intended to do it correctly with a mild bowl porting also.
All that extra money is probably better spent towards buying better heads in the first place, if you are performance minded.
JMO
This site will not enlarge pictures.
Old 02-03-2007, 02:29 PM
1:94s
I agree that 2:02s will not gain much if anything because of shrouding, how about considering a larger exhaust valve like 1:6, which will gain you more than a 2:02 intake valve...
1.94 heads or 2.02 jeff germano Engine 10 05-23-2013 05:38 PM
2.02 vs. 1.94 valves stfinney Engine 14 07-03-2005 12:25 PM
1.94 vs 2.02 NXS Engine 13 12-28-2004 11:09 AM
2.02 or 1.94 valves?? stfinney Engine 13 04-16-2003 07:38 PM
2.02 valves on stock 302 pistons mustang66maniac Engine 3 08-06-2002 11:30 AM
