# 1 on dist cap chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2002, 05:01 PM
Post # 1 on dist cap chevy
I had to put intake gaskets on a 454 now wont start when i put distributor back in rotor keps going to # 8 was told #1 was the terminal just forward of the connector(hei) is thic correct or not. i put #1 tdc on compression many times but dist falls in with rotor terminal 2 from connector
HELP
Old 12-15-2002, 05:12 PM
Post
You need to get the oil pump rod lined up so the dist will drop in with the rotor pointed where you want it. You could stick a long screwdriver in the dist hole in the engine and turn the drive. Or you could line the rotor up and bump the engine over until the dist drops into place, then bring #1 to tdc and recheck it, you may have to do it a few times to get it right on.
Old 12-15-2002, 05:19 PM
Post
[quote]Originally posted by Jason:
<strong>You need to get the oil pump rod lined up so the dist will drop in with the rotor pointed where you want it. You could stick a long screwdriver in the dist hole in the engine and turn the drive. Or you could line the rotor up and bump the engine over until the dist drops into place, then bring #1 to tdc and recheck it, you may have to do it a few times to get it right on.</strong><hr></blockquote>
Old 12-15-2002, 05:23 PM
New Member
Talking
Someone correct me if im wrong , but it doesnt matter where your rotor points as long as you are on TDC and you use the correct firing order. On my 454 i made sure the rotor was pionted at the #1 cylinder ( because its easy to remember when you reinstall the dist.), which is two terminals in front of the Hei hook up.
Old 12-15-2002, 06:02 PM
Infomaniac's Avatar
Twin Turbo Drag Boat
Last journal entry: Random In Progress Shots
Post
If you did not change anything. The first one fwd of the connector is #2. #1 will be just after that one looking down clockwise
