1 gal. paint can? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2013, 06:04 AM
Last journal entry: Still running strong
1 gal. paint can?
I bought a new unused 1 gal. paint can to hold the 4 qts. of metallic base coat, the base coat came in 4 qt. cans. Pored them into the 1 gal. can, then last night I was thinking about the painted liner inside the new 1 gal. can an I worried about the base coat dissolving the the painted liner. This is one of the cans you can get at Home Depot. Should I worried about this?
Old 05-13-2013, 08:32 AM
That is a damn good question, never thought about it. That liner is designed for waterbase paints so the can doesn't rust. What it is made out of, I don't know.
Hopefully someone who does can answer this, I know I want to know.
The Following User Says Thank You to MARTINSR For This Useful Post:
dogwater (05-17-2013)
Old 05-13-2013, 10:00 AM
BarryK's Avatar
You are probally fine, a simple test is put a blob in the can and check in a day.
The clear and activator cans are also coated but clear, the same coating as used (you may have read about) the coating of food cans.
Valspar is the big seller of this coating and up until about 8 years ago we also used the gray lined cans for one of the bed liners we made and discontinued a Poly-sulfide type.
A simple test should tell you the story.
The Following User Says Thank You to BarryK For This Useful Post:
Old 05-14-2013, 05:33 AM
There the cans you can buy at Home Depot. Metal cans.Though it was a good idea to mix all the base coat together. Didn't really think about the sprayed on liner untill I was laying in bed. I'll open it back up today an look.
Old 05-14-2013, 05:35 AM
deadbodyman's Avatar
Wiki Edits: 11
I use saved food cans all the time for my paint and they work well I've never once had the lining disolve with any of the solvents we use...I wonder what that stuff is ??
Old 05-14-2013, 09:31 AM
Pour some paint out of the one gallon can, and wipe inside the exposed inside of the can. Is the liner softened, or dissolved?
The Following User Says Thank You to DanielC For This Useful Post:
Old 05-15-2013, 10:00 AM
Mitchman's Avatar
Grand Master of the Universe
It's likely activated or epoxy for VOC's. I'm guessing good to go.
The Following User Says Thank You to Mitchman For This Useful Post:
Old 05-16-2013, 05:02 PM
I don't think you'll have any troubles. But you can allways pour it back into the quart cans after mixing it all together.
Old 05-16-2013, 05:48 PM
Last journal entry: Body
Good idea to mix them, I never used the lined cans, but I would be surprised if you had any trouble.
5 gal of pig crap = 5 gal of gas cboy Hotrodders' Lounge 9 10-12-2006 11:11 AM
New Gal Bea Introduce Yourself 2 09-20-2006 01:53 PM
Glessen 63 old Gal glessen Introduce Yourself 5 08-28-2006 05:10 PM
New Gal on the block Seagal632 Introduce Yourself 4 08-27-2006 12:03 AM
New Gal checking in! cobra621 Introduce Yourself 3 09-25-2005 11:51 AM
