Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1 more cs130 wiring question
Old 07-11-2006, 06:52 PM
84cutlass 84cutlass is offline
i have a 1984 cutlass with a chevy 350 engine ,i added the serpentine set up off a 91 1500 is it okay to hook the thick red wire from the plug to the back of the alternator and run a heavy guage wire from the terminal in back of the alternator to the battery also i spliced the brown idiot light wire directly to the L wire on the plug is this correct. i turned the key to the on position to see if the light came on and it did so is it correctly wired thanks
