1 piece oil pan gasket.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2010, 11:22 AM
hi guys,
did anyone ever install this oil pan gasket??
http://www.summitracing.com/parts/FEL-OS34510T/
is it normal that when placing the pan on it doesn't flush because of the front seal being very thick??
Summit says that when i bolt it down it will be OK..
my old 4 piece gasket was a thick front seal but is thinner then this one..
did anybody go through this already??
Thanks,
Ron
Old 07-28-2010, 04:10 PM
That sounds about right. You should be able to just start the bolts, then tighten the pan down uniformly. The metal torque limiters will tell you when its completely tightened.
Old 07-28-2010, 04:19 PM
BOBCRMAN@aol.com's Avatar
Try that gasket with an aftermkt aluminum cover if you wan't some real concerns. It will test your patience and bolt tensile strength..
Old 07-28-2010, 11:24 PM
thanks guys,i got it..
Help with one piece pan gasket chewyscool Engine 2 09-06-2009 12:13 PM
Problems with Fel Pro one Piece oil pan Gaskets Double_v23 Engine 15 11-26-2008 08:02 AM
Need suggestions for sbc 1 pc oil pan gasket twborbely Engine 1 12-02-2007 07:30 PM
Changing pan gasket on 350 chevy rapsag Engine 16 08-04-2005 07:55 AM
351 Cleveland Oil Pan Gasket L88VETTELOVER Introduce Yourself 1 12-11-2004 10:45 AM
