Hotrodders Bulletin Board
#1
1 Piece Oil Pan Gasket Question
I am getting ready to install the fel pro 1 piece oil pan gasket on my 327 SB.Any suggstions on how I should install this?I want to make sure it is installed properly without any leaks.Any help is appreciated.Thanks,
Eazy |
#2
The gasket is to be applied dry, do not use any adhesives or sealers. It fits pretty tightly on the timing cover bottom and the top of the rear main bearing cap so that will hold it in place. Install all the bolts before you tighten any down then tighten in a criss-cross pattern starting in the middle. Do not over tighten, if you see the gasket start to squish out from under the pan that is too tight.
Vince
Here's to you DoC, you will always be here. My project 34 http://www.hotrodders.com/forum/34-...ght=34+progress |
#4
Tighten bolts in an "X" pattern. Do one on the left center then do one on the right center. Move to the next one then do the the one that is in an "X" from it. Additionally you do not want to run the bolts down all the way at once. Just snug them all up and then repeat your pattern until all are at the proper torque. That should take about three rounds of tightening. Vince
#6
I thought all the Felpro one piece rubber pan gaskets had compression grommets. I guess that the Chevy's don't..... |
#7
They do, but you can still over tighten them NLOL. Vince
#8
Its always a good idea to apply a very small amount of silicone sealer to the corners of the gasket.I have that same gasket on my nova. It wont hurt anything and its good insurance against a leak. IMO....
Back to top |
Similar Threads for: "1 Piece Oil Pan Gasket Question"
| Oil Pan Gasket Question | EazyDuzIt102 | Engine | 8 | 06-21-2006 07:55 PM |
| high volume oil pump question | jstaten | Engine | 4 | 01-15-2006 11:56 PM |
| M.S. requested joke thread | hotrodit | Off-Topic | 186 | 12-20-2005 12:26 PM |
| oil pan question | 84bird | Engine | 3 | 05-03-2005 01:23 PM |
| Felpro 1 piece oil pan gasket??? | dpjmw | Engine | 8 | 12-18-2003 09:21 PM |
