From A 1 Ton to a 1/2 ton - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2004, 06:45 PM
Flanders's Avatar
I have a 1949 chev 1 ton that we are looking to change to a half ton. Is there a frame that from a newer truck that will work on this old beast? If not where would a guy start looking for a old one to restore?
I also would need the box as well. Any tips would help
Thank you in advance
Flanders
Old 07-24-2004, 12:53 PM
40fordtruck_son's Avatar
Let the wheels of life roll on
Last journal entry: donor truck for hot rod hellion
...... would a 70's 2wd chev frame work?
Old 07-24-2004, 02:50 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
my uncle has a 1930 ford truck that he converted into a 1/2 ton. He used the orignal frame but made it shorter.
Mike
Old 07-26-2004, 10:47 AM
bullheimer's Avatar
NEVER use credit cards!
just change the axles and springs
Old 07-26-2004, 01:23 PM
you dont wanna keep the same frame. the frame of a one ton is way to heavy fer roddin'.
mine was ton and a half, man was that frame Friggin heavy
Old 07-26-2004, 11:17 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
a one ton frame wieghs almost 1000 lbs MORE then the half ton frames & are almost 1/4 inch thick. what ya might want to do to make it easy or simpler is to either stretch a 1/2 ton frame to make it LOOK like a 1 ton. they are the same width, just make sure the body mounts ar in the correct place OR make your truck a TRUE 1/2 ton & leave the 1/2 ton frame alone since it's a shorter wheel base & everything you have will bolt rite up to it...
orrrrrrrrrrrr, try a s10 frame swap http://www.usbody.com/Pages_Info/F-Installations.htm scan down to the 47-54 mock up....joe
