1 ton lowered suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2003, 07:14 AM
slider in wa's Avatar
Slider in Wa.
Post 1 ton lowered suspension
I called Centech to buy the parts thinking i needed dropped spindles, dropped springs, upper and lower control arms. The lad said all i need was the dropped spindles. That i could use the stock springs and control arms and drop it 3 " with the spindles alone.
Does using the stock parts cause a caster or camber problem? Any advise will be put to good use. This is for my new 48 Chev COE truck (On a 1 ton 1988 suspension) Thanks in advance!!!
Slider in Wa.
Old 04-19-2003, 07:23 PM
jalopy45's Avatar
Cool
He told you the truth. You can go another 2" with springs but then alignment problems start and you have to space out the upper control arms or shorten the lowers or replace them.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
