1 wire or 3 wire alternator - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2006, 05:51 AM
runn141's Avatar
what one is better ive got a 100 amp one wire aftermarket and a custom built 3 wire 160 amp remanufactured? ive got use for both one for my rod and one for my truck. which one should i use with each of em. im just looking for a second opinion.
Old 11-24-2006, 06:24 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
The best choice is the 3 wire..
The 3 wire has the options for remote sensing, and you can run an idiot light..also the regulator does not require an RPM "Bump" to wake it up..
The 1 wire is very easy to install, but has some draw backs..it needs an RPM bump to get it to charge, it has no provision for remote sensing, It has no provision for Idiot lamp..
And personal preference, Which is at your skill level to best install...
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 11-24-2006, 10:57 AM
Wiki Edits: 49
I agree with Doc. I've always gone under the rule that if you're running a lot of accessories (like Air, stereo etc.) go with the 3 wire. Something simple then a 1 wire will do. I'm no electrical expert but that's the rule of thumb I use.
Old 11-24-2006, 02:53 PM
runn141's Avatar
i believe ill use the 3 wire on my rod then, my old truck will get the other cause it doesent have many accessories. but will the one wire be enough to run extra fog lamps if i decide to use them later?
Old 11-24-2006, 03:10 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
100 amps should be just fine on a bare bones truck..
Run lighting relays, and you'll get better performance on the lights with less current loss in the wiring.
Doc
Innovations
Old 11-24-2006, 03:15 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I used a 3 wire,
In the event of a failure away from home
EZ to get a replacement
Any parts house would have one that can get you back on the road
Bryan
Old 11-27-2006, 10:27 PM
Northstar John's Avatar
single wire alt.
Hi Doc: Can you explain "RPM Bump".
Old 11-28-2006, 01:34 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Yes, You have to throttle to around 1500 RPM to get the Regulator to turn on ..before or below, it won't be charging or self exciting the alternator..
A Scenario: You, for instance come out on a Cold winter day, start the car, and turn on the wipers, lights, heater, electric defrosters, and let it idle in the driveway to warm up , along with the drain of a "cold start"..and all that time not only will it not be charging, it will be discharging on a max load...If it's a short ride..say, to work, and the battery is weak enough, it may not start 8 hours later..
Doc
Innovations
Old 11-29-2006, 11:11 PM
1 wire Alt.
Thanks Doc.
What's the proper way to wire an alternator? 70bird Electrical 18 08-14-2010 12:24 PM
One Wire Alternator Hook up? HotRodMan Electrical 11 09-15-2006 04:37 PM
alternator wire hanging in mid air?! pcoghlan Electrical 11 03-21-2006 02:47 PM
one wire / three wire, alternator hookup 65truck Electrical 1 10-24-2003 03:59 AM
57 Chevy generator to altenator swap Rodrunner Electrical 2 07-17-2002 09:59 PM
