Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1 wire or 3 wire alternator???
  #23 (permalink)
Old 01-06-2006, 06:55 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
Originally Posted by oldguy829
Great information. How about going a step farther. There are 100 amp, chrome, 3 wire alternators on ebay for around $75.00. they are listed as "GM" not Delco.Is this a desirable piece, or junk? how can I tell? .
You can get rebuilds (NOT GM) from the parts store for like $20 to $60 bucks..and not take a chance, will it work, will it arrive? and if not, can just go back and get a replacement..over the counter..
Fatrodder also lists a 21 circuit (more than I need) wiring harness for around $120.00. Is there a big difference between the quality of this system and a "name" brand? or is the "ease of installation/tech support" the difference?
Will I need to also purchase the terminal blocks/relays/fusible links etc. recommended in the articles no matter which harness I buy?
There is a Thread on this forum, titled " Wiring harness, which do you prefer?" Has about 300 replays on it, about the pros and cons of different harness kits..I suggest you go there and read the information first hand from those that have used them..Ron Francis (owner of Ron Francis harness's ) and the owner of EZ 2 install are both on that thread too answering any TECH questions you may have..
I feel capable of following instructions and wiring the car, but maybe not up to adding relays and terminals blocks in the right places, or upgrading the wiring size for a backseat battery mount, without some very specific instructions. What would you recommend for the prolific do it yourselfer, with limited electrcial expertise.
Most of those harness come with very easy to use Instruction manuals, some more involved than others (this is where that other thread will be helpful in deciding) Actually if you have rudimentary Wire skills, you SHOULD be able to do the job no problem! (Solder, strip, read and follow a schematic, wire color coding , wire gauging) I always suggest go to the car with the instructions and read, and read until you can do it in your sleep before you start..know where everything is supposed to be..and if you get stuck..were all here to help if we can!
Doc
