1 wire alternator ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2009, 08:09 AM
So i did some research on them after i purchased one. I know how to wire it and all that. When i bought it my intention was to clean up the engine bay. Now i am seeing concerns about not getting enough voltage for lights and accessories. Is this true. I am hoping i can run a very short and heavy gauge wire and be ok. Lots of input and hopefully reassurance im doing the right thing is greatly appreciated.
Old 02-12-2009, 11:13 AM
Wire size
generally, the wire size you'll need to the main buss is as follows:
Amps Wire Size
15 14
20 12
30 10
40 8
50 6
70 4
100 2
This will keep the wire from overheating, and prevent a serious voltage loss due to excessive resistance. You may want to run the charge wire directly to the battery, in the case of a 100 amp or better alternator. The sizes shown are for SUSTAINED loads.
Old 02-12-2009, 11:55 AM
your question is not clear but any/all alt's do have a "ramp up" amps output per rpms...
so if it isn't spinning fast enough at idle due to pulley ratios it can cause a voltage drop with alot of accessories turned on...
or if the wiring harnesses/switches/connects/devices/etc are shot and grounds are bad causing to much resistance it can show a voltage drop at idle....
rephrase/clarify your question???
Old 02-12-2009, 03:22 PM
302 Z28's Avatar
One wire alternators belong on tractors, and other industrial equipment IMHO, not cars with lots of accessories.
Vince
Old 02-12-2009, 05:36 PM
kleen56's Avatar
Vince
That's interesting??? I changed mine out on the 56 Ford truck because I hated looking at the voltage regulator and all the wiring going to it. I replaced it with a one wire GM alternator at 100 amps. I have not had a problem with any accessories so far. The only thing I don't care for is when I first start it, the alternator won't charge until I give it a good rev and bring the rpm's up, after that it will keep charging and works nicely. No fuss with the wiring either. Very simple application.
Old 02-12-2009, 06:05 PM
life is a temporary assignment
That's all I run on my car's,Never had a problem,Not one time..
Old 02-12-2009, 06:10 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I have used 1 wire alternators for years and never had a problem either.
Old 02-12-2009, 06:55 PM
V8 Biker
I Run 1 wire 140 amp Chrome Alternator
On our application of V8 Bikes and trikes, we usually run a 100amp 1 wire alt.
Most of the guys say 80 amps are enough for our application.
I run a 140 amp on mine, as I usually run PIAA 1400X FOG lamps all the time, headlamp all the time and running lights and reverse the fan in cold weather to blow hot engine air on me to thaw out my gonads. I have converted all the turnsignals, brake lights etc to LED's for less draw and more light. I dont have a problem with charging even if the 350 ZZ4 w/cam idles at 650rpm. We also run electric waterpump, electric fuel pump, smarttire tire pressure monitor and a small Odyssey PC680 battery for space savings.
Added the extra amps for cellphone charger, Muth Mirrors,(ones with LEDs in the mirrors) sequential turn signals in the license plate and heathed clothing leads.Also have 5 dash gauges and a Autogauge Monster Tach. Havent checked the amp draw out but I'm sure I'm not even close.
Have 55,000 miles on this setup, with HEI distributor and Quadrajet carb and is very reliable.
Cheers
Aldo
Old 02-12-2009, 07:15 PM
302 Z28's Avatar
1 wire vs 3 wire, the debate rages.
Vince
Old 02-12-2009, 07:45 PM
Sorry Vince.But they sound like they are trying to sell there harness.I never had any trouble with the one wire.That's what's good about this country.Everyone can make there own mind's up.To use what they like.I do believe that if it work,don't change it.Always worked fine for me.And you can pick one up at almost any parts house now.
Old 02-13-2009, 07:26 AM
302 Z28's Avatar
The reason I prefer a three wire is you can wire up a choke to it, you can wire up a light, you can get one at any auto parts store when your on the road. Early on in my build I came real close to going with a one wire. I made the decision to opt for availability and added features over aesthetics. As you stated....just one's choice.
Vince
Old 02-13-2009, 09:29 AM
just a comment, food for thought:
what you give up with a one wire alt is the ability to tune the alt output volts using the external regulator voltage sensing wire resistance...
(you can fool the alt to put out more or less volts)
for batt charging safety, many one wire alt's are set/fixed at only about 13.4V(?) output...
"if" you do have ohms resistance or amps overload on the harness there may only be 12V at the dist at idle,,,
got 13.2V at the dist at idle with a one wire alt due to all new $XXX wiring harnesses your fine...
for best spark quality, new cars do deliver 14.4V to the dist at idle to work with the bigger plug gaps ...
which method to choose depends on what your working on and for what purpose,,,cruiser only or race only...
Old 02-13-2009, 02:58 PM
This is one of those times when all you got to do is look at the oem, They used the external sensing wire and field feed for a reason.Many use one wires and love em but it is so simple to wire a delco alt like the oem why bother ?
Old 02-13-2009, 03:15 PM
Why .... I try to keep my engine area very clean and neat.I only have to worry about one wire.And it's very easy to hide one wire.Why have a bunch of wire's when you don't need them.That's just me.I like to look under the hood and see a motor,Not a big bird nest!!!
Old 02-17-2009, 06:35 AM
Hey New Interiors, I am the same way with the engine bay which is why i am going to try it out. I will not have many accessories to run. Here is the list.
Elec fuel pump
Head and tail lights
HEI dizzy
Elec choke
Guages But maybe mechanical I havent decided yet.
Maybe wipers if i get caught in the rain.
There will be no heater or radio or any other frills. When everything else is done and I am totally happy with everything I will switch to LED tail and brake lights. I am even thinking of shaving off the side marker lights for a clean stealthy look.
Alternator excitor wire voltage guba_unus Electrical 9 05-01-2008 04:30 PM
3 wire alternator hookup GCD1962 Electrical 10 04-21-2008 08:29 PM
One Wire Alternator?? budthespud Electrical 9 11-24-2007 08:06 AM
Wiring a 1 wire alternator and starter 71novactb Electrical 7 02-09-2007 09:14 PM
alternator wire hanging in mid air?! pcoghlan Electrical 11 03-21-2006 02:47 PM
