1 wire alternator question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2010, 05:53 PM
I'm building a 1984 prostreet camaro that is for show and go. I have gone a long way to cleaning up the engine bay which included re-routing alot of wires to hide them.
I have a Powermaster 1-wire alternator. From the stud on the back I ran a 8 ga. wire to the battery in the trunk. My original harness has a small brown wire that goes into the side of the alt. I believe this wire is for my factory in-dash voltage gauge. Can I move this wire to get it out of the engine bay? I was thinking maybe I could move it to a switched +12v source. Any help would be greatly appreciated.
Old 09-12-2010, 07:50 PM
Chevolla's Avatar
Red,if you want to use the original gauge any 12v switched source will work.I run a 1 wire in my Camaro.I wired my original volt meter the same way,cleans up the engine bay.Also run my Toyota and Vega the same.
Old 09-13-2010, 02:05 AM
Thats great news. Thank you.
10si wire help monte ss Electrical 6 08-03-2010 06:26 PM
new welding wire oldred Body - Exterior 93 05-07-2009 04:40 PM
Fried wire from ignition to soleniod? frankenvette Electrical 4 07-31-2008 02:45 PM
Help with Digital Dash Install jvgrago Electrical 4 05-16-2008 07:16 PM
85 s-10 distributor wiring question strracer7 Electrical 1 09-29-2003 03:39 AM
