1 wire alternator wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2008, 01:59 PM
racinghick's Avatar
I have a '64 Ford Fairlane Sports Coupe with a 302 in it. It has been converted over to a 1 wire Delco- built from a generator. I would like to know how to connect the wires to it ,and what I need to do about the voltage regulator. The alternator is internally regulated. I can't get the thing to charge the battery. I really need a diagram of the wiring of this conversion. Danny
Old 04-08-2008, 02:12 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Remove your old voltage regulator and individually tape up the wires, also sape up your old alt. or generator wires. All you have to do to hook up a one wire alternator is run one wire ( at least 10 guage) from the alternator to the starter solinoid...connect it on the same lug that your battery is connected to.
Old 04-08-2008, 03:03 PM
racinghick's Avatar
[QUOTE=racinghick]I have a '64 Ford Fairlane Sports Coupe with a 302 in it. It has been converted over to a 1 wire Delco- built from a generator. I would like to know how to connect the wires to it ,and what I need to do about the voltage regulator. The alternator is internally regulated. I can't get the thing to charge the battery. I really need a diagram of the wiring of this conversion. Danny
Old 04-08-2008, 03:09 PM
Lost in the 60's
Wiki Edits: 4
Like I said...its easy. You do not use any of your existing wireing. You run a 10 guage wire either to the battery terminal on the starter solinoid or if its easier for you...you can runit directly to the battery positive post. Thats why they call it a one wire alternator...one wire to the battery...thats it.
Old 04-08-2008, 03:21 PM
racinghick's Avatar
one-wire alternator
So I don't have to do anything with the plug-in area on the alt? Just the single wire to the solenoid or the battery and nothing else. Cool! Thanks for the answer. Guy at resto shop has it all screwed up. Hooked up wires to the plug-in on the alternator and causes a dead drain on the battery.
Old 04-08-2008, 03:22 PM
Wiki Edits: 31
also, with a 1 wire you might also need to rev the engine a little b4 it will start charging
Old 04-08-2008, 04:35 PM
Lost in the 60's
Wiki Edits: 4
Correct...when they converted the alternator those others were eliminated. And you do have to rev your engine to kick it in. If it does not work now then the man converted it wrong. You can buy a true one wire alternator in about any size you want at Jegs. www.Jegs.com.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
How do I wire a 3 wire alternator when I used to have a 1 wire alternator??? billsbird Electrical 7 09-05-2007 09:01 AM
Starter Problems Jsquier Electrical 5 08-26-2007 05:32 PM
question about ballast resistor and wire gauge redneckprofessor Electrical 25 06-09-2007 01:50 PM
1986 Cutlass wiring Q's again :( ChrisMiddleron Electrical 12 07-16-2005 04:22 PM
