1 years worth of an annoying code... (4.3 TBI) - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-19-2013, 05:13 PM
InDeep****Now
Well, still getting the code... I have a digital dash, and my odometer is now saying error, and my tripdometer is flickering all kinds of different numbers... Not sure if that's the ecm, or dash it's self. Where is the mileage memory located? Can't be the ecm, because even when the ecm is changed, the mileage doesn't change.
  #17 (permalink)
Old 05-19-2013, 05:58 PM
I assume its pre-OBDII being its a code 13? The reason the CEL doesn't come on until you drive it is, your o2 doesn't have a heater. The o2 doesn't get hot enough at idle, Doesn't go into closed loop, Computer doesn't even look at it. Once you take off down the road the o2 heats up, goes into closed loop, computer looks at it, and then see's something it doesn't like. Flips on the CEL. Going off your definition of the code it's saying the o2 isn't switching. IS IT? Should be 0-1v give or take a tenth. Should easily hit atleast .9v at WOT, and stay there as long as your foot is in it, then, should momentarily drop to near 0 when you close the throttle from that WOT run. Also you cant use a ohm meter to check the powers and grounds, you need to do a voltage drop.
Let me refrase that... you can ohm the grounds, but it's not the best way. You can get burned & miss something by doing it that way.
4.3 tbi, code 13
Is it worth going to College for 2 extra years? xRYKERx Off-Topic 15 01-25-2011 08:03 PM
Annoying DJs... Blazin72 Off-Topic 17 01-04-2007 11:03 AM
Annoying trans leak Blob Transmission - Rearend 4 05-28-2006 05:02 PM
Getting real annoying.... zipfactor Electrical 12 08-18-2005 03:37 PM
Kind of annoying......... BstMech Hotrodders Site Suggestions and Help 3 03-05-2003 12:15 PM
