89 chevy p.u. 350. Replaceing stock 350 with a 350 thats got about 10 to 1 comp. Keeping truck with the TBI and stock computer and all. The stock setup has a knock sensor to it. Question; Will the knock sensor work like it did on the stock setup? Also, what about a performance chip? Someone said a chip wasn't nessary on my engine. 350 305 heads, med. cam, TBI w/swirl riser, headers. I ran this engine in another car and ran great. High compression, pump gas and all. Just thinking about the knock sensor, if it'll help any.
The knock sensor circuit will still be active unless you eliminate it via custom chip.
If the replacement engine has a cam much more radical that the one in the engine you are replacing, it may require a custom chip as your system is speed density and only recognizes pre-set values. If there are any bad idle characteristics, you need to talk to a chip burner. The use of a chip usually changes fuel delivery and timing events, but in the case of speed density, it also allows certain engine modifications. |
Kultulz, thanks for the input. I'll talk with a chip burner and see what we can come up with. The knock sensor was just a thought. I can do without it but if there was an advantage to it I'd use it.Thanks for again
I would retain the knock sensor as if you get a bad load of fuel or there is a malfuction in the timing curve it will retard the ignition advance to prevent pre-ignition.
KULTULZ, any recommends on chip burners?
Well, -here- is my personal choice, but there are many companies. Check out as many as you can to get exactly what you want and price.
