10:1 piston - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2013, 02:31 PM
10:1 piston
10:1 piston can work with the vortec head ?and on same engine i had holley 4150 db pump will it work with 700r4 4x4 truck,or what is the best choice for cab the truc not daily driving.thanks
Old 01-19-2013, 03:15 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
There's no such thing as a 10:1, 9:1 or whatever c.r. piston. There are numerous configurations that are included in the static c.r. formula, but several other variables, bore size, gasket thickness, chamber size.
Are your pistons standard bore, dished, flat or domed, and what's the volume?
Semper Fi
Old 01-19-2013, 11:44 PM
i am not clear to ask
engine 350. 030 over ,piston domed 10 to 1,i juist want to know my vortec head #062 can work right with it.and i had holley 650 db pump,i try to set togetther on engine to install on my chevy truck 4x4, transmisson 700r4,the holley 650 db pump can work with 700r4?or i had to change my cab,sorry my english too bad to make you understand
Old 01-20-2013, 08:07 AM
BOBCRMAN@aol.com's Avatar
Dome piston won't work with Vortec head. Double pump carb won't work well on a streetable truck.
Old 01-20-2013, 10:49 AM
piston
i am not sure it a domed piston or not but i see top head of piston litle taller than flat top .my truck it not daily driver so the cab holley i had it not right cab to use on the truck?let me know what is right cab to used on hi perfromance truck
Old 01-20-2013, 12:37 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
IF it's domed, it has a good chance of hitting the head. You will need to mock up the engine using clay on the top of the piston. Then using the head gasket thickness you plan on using, bring the piston slowly up towards TDC until it either hits or goes on around past TDC. Remove the head and see what you have.
Double Hump or Vortec??? is a post showing the Vortec dome compared to an earlier SBC dome.
You need to give details of the gears, weight, how it'll be used, intake type, cam, etc, to answer the rest. A list of things that will help answer you is here.
Old 01-20-2013, 07:30 PM
it is chevy vortec head
it is vortec head casting 062 ,will upgrade on 85 chevy 4x4 with 10:1 piston,truck not daily driver,it stock grear end,700r4.holley db pump,High Rise Aluminum Vortec ,camshaft will upgrade too.my question is my vortec head can work with my piston i had now? second my cab holley it will work rigth when it install on truck? WHAT IS BEST CHOICE CAMSHAFT.THANK
Blazer dual piston setup Vs. SSBC dual piston calipers! veltboy314 Suspension - Brakes - Steering 1 11-28-2010 06:37 AM
Old TRW Piston Part # 234-98 396 Chevy Forged Piston? heathj1 Engine 1 07-21-2009 05:14 PM
positioning piston rings on piston geormor9 Engine 5 03-21-2009 05:33 PM
RE:Flat Piston To Domed Piston Bgcooley Engine 10 09-04-2007 12:59 PM
302 piston dim. compared to 327 piston Dave Y. Engine 2 09-25-2002 08:55 AM
