10-5-1- or 11-1 forged pistons for 454 chevy bored 30 0ver - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2012, 07:08 PM
looking for a piston set for a 454 bored 30 over in the 10.5 to 11 -1 compression range with 118 cc heads cant seem to find any , ideas anyone
Old 09-20-2012, 07:27 PM
vinniekq2's Avatar
Where to buy them? or if its a good idea?
Old 09-20-2012, 07:41 PM
SSedan64's Avatar
TRW L2465F-30 open cham. heads only, 460ci., 10.86Cr., 1.640 CH, .226" dome, with 119cc Chamber.
Old 09-20-2012, 07:52 PM
reply
well here is what i have , 454 4 bolt main bored 30 over the block is stamped high perf on the back. eldebrock 2-0 intake large tube headders 850 holley, wanting to build around 600-700 hp and add a 200 shot of nitrous,going to use 781 heads now and buy some alum when budget allows it, was thinking about a xe 284 cam from comp cams. not sure .will work
Old 09-20-2012, 08:00 PM
vinniekq2's Avatar
If you are truly building a 700 hp engine and adding NO-2 then you better save up to buy all the parts at once.An engine that will last making 900HP and all that torque will need premium parts everywhere.
Old 09-20-2012, 08:12 PM
reply
nitrous use will be few and far between, on occasional trips to the track
Old 09-20-2012, 08:23 PM
vinniekq2's Avatar
Nitrous on a bb on street tires is just a waste of nitrous. My 380 hp 454 LS-5 would melt the street tires with any launch all the way through drive. My nitrous bottle was never filled once in the 5 years I had the car.
Old 09-20-2012, 11:14 PM
Rhino370, The easiest way to get to 600+ HP is with a 489 cid rotating assembly. This is a 4340 forged steel crank, H-Beam rods with ARP bolts, forged pistons, main bearings and rod bearings, and ring set. The 781 heads with good porting and a solid lifter cam in the 250-260 duration should put you over 600 hp. Check out the kits at Summit Racing, Jegs, and CNC Motorsports. I purchased mine from CNC Motorsports. I got to choose the brand of pistons I wanted. i think they use KB Icon Forged pistons, Mahle Pistons, and JE Pistons in their kits. Choose from Scat or Eagle kits.
lighter forged pistons (KB vs speed-pro) worth $325 on a chevy 454 Berres Engine 15 05-18-2011 09:57 AM
1989 454 bord 40 0ver Ed Galindo Engine 2 07-19-2010 12:13 PM
Chevy 3.3l v6 forged pistons Camino78 Engine 6 10-30-2009 11:20 AM
are all 454 pistons forged? chevelle4542speed Engine 2 01-18-2007 06:15 PM
Chevy 383 What cam to run???? Also Forged or hyper pistons?? 89SDime Engine 19 02-27-2006 11:59 PM
