10.5 or 11 inch clutch - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2007, 10:29 AM
I have a new 10.5" stock flywheel. What are the benefits of an 11" over a 10.5 in. clutch assembly? It sits behind a 350 w/ 430 hp. Thanks!!!!!
Old 12-19-2007, 07:54 PM
You can't necessarily go by clutch size when you're talking flywheels. The 10.5" clutch (actually 10-3/8") could be found on either size flywheel, depending on application.
The few 11" clutches I've dealt with were stiffer at the pedal, and require the large-diameter (14") flywheel. They will transfer more power due to the greater surface area and won't slip as much under hard use/abuse. The smaller flywheel allows a little more ground clearance, if that's an issue, and the smaller clutches are way easier on your left leg, unless you use a stiffer aftermarket pressure plate.
Chevy used the smaller clutches in standard-duty car and some standard truck applications, and also on some high-performance cars such as 302's and 427 Corvettes. Cars with the heavy-duty clutch option, such as police cars and taxis, got the 11" setup.
Taurus SHO clutch issue... I know, big surprise... ViperMonster800 Transmission - Rearend 3 04-04-2006 09:33 AM
School me on clutch discs RB401 Transmission - Rearend 2 06-22-2005 11:24 PM
Clutch not releasing Chevy Thunder2 Transmission - Rearend 4 01-05-2004 06:10 PM
clutch linkage!!? chevyelc81 Transmission - Rearend 11 08-01-2002 07:46 AM
How to hook up torque converter clutch without a computer Roy Newton- exprotech Transmission - Rearend 3 12-28-2001 07:21 PM
