10 bolt to 12 bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2005, 06:48 PM
10 bolt to 12 bolt
hi guys
if i go from a 10 bolt to a 12 bolt rearend in a 72 chevelle , will i need to shorten or lengthen the driveshaft? or is the pinion yoke position similar enough that no modifications are needed?thanks.
Old 05-03-2005, 06:47 PM
Ratchet's Avatar
Last journal entry: Ontario Camaro Nationals 2008
Its been a while but as I recall when I put the 12 bolt in my 72 chevelle stock car in sig the drive shaft was identical.
Ric
Ric
Old 05-04-2005, 07:26 PM
thanks for the reply. i think you're right. i took some measurements on both rearends. it seemed to me that the pinion yoke locations were the same . i think it'll be ok.
12 bolt with 10 bolt carrier? JamesRS Transmission - Rearend 3 01-17-2005 09:59 PM
New 12 bolt Rear/ questions. RObs71Nova Transmission - Rearend 1 12-27-2004 08:19 AM
What is This 12 Bolt Posi Out Of?? camaroman7d Transmission - Rearend 10 12-10-2004 05:57 PM
just swapped to a 12 bolt and the yolk is wrong! Destructo Transmission - Rearend 6 10-14-2003 09:54 PM
10 bolt or 12 bolt rearends ? a62chevy Transmission - Rearend 5 09-21-2003 06:16 AM
