10 Bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2008, 05:25 PM
10 Bolt
Hi
My car (26T) has a 8.2 10 bolt GM rearend. It is 51" from backing plate to backing plate ,the axle tubes from houseing to flange are 17". Anyone know what kind of car it came out of?
Thanks
Old 02-27-2008, 01:17 AM
66sedanman's Avatar
The chevy II has the most narrow 8.2 10 bolt at 58" flange to flange,
Of the Gm vehicles.
someone correct me if im wrong
Old 02-27-2008, 07:19 AM
CDJr's Avatar
Experienced Amateur
Last wiki edit: Automobile body and frame rotisserie
Wiki Edits: 2
Theres probably a code stamped into it somewhere. I think most Chevys are on the front of the passenger side and Pontiacs had some on the rear of the drivers side.
Old 02-27-2008, 08:56 AM
I'm just trying to find out in case I would ever need an axle. Maybe it was narrowed, but I don't know why someone would narrow a 8.2 instead of the 8.5 or a ford.???
Old 02-27-2008, 09:40 AM
66sedanman's Avatar
hope this helps,
http://www.carnut.com/specs/rear.html
Old 02-27-2008, 09:51 AM
Thanks,but what do they mean by "outside widths" where are they measuring from?
Old 02-27-2008, 11:40 AM
66sedanman's Avatar
Most measurements I see go by outside axle flange to axle flange, (meaning were the rim would sit against).
Old 02-27-2008, 11:50 AM
Thanks,guess I'll have to take the wheels off someday to get that measurement
Gary
Old 02-27-2008, 12:20 PM
66sedanman's Avatar
LOL, I will measure my chevy II later,
Plate to plate , axle to axle.
Old 02-27-2008, 12:25 PM
GOOD MAN!!!! What year is it,or were all Chevy II"s the same?
Gary
Old 02-27-2008, 01:34 PM
66sedanman's Avatar
Well my rear is 51" Backing plate to Backing plate.
My car is a 66 chevy II
Gm used this rear from 62 -67 in the chevy II
They also put in a 12 bolt in 66 and 67 in the Higher HP models.
Good luck finding one used for less than $1800
Old 02-27-2008, 01:43 PM
Thanks a lot. I don't need one , I just wasn't sure what it was out of
Gary
Old 02-27-2008, 01:48 PM
66sedanman's Avatar
No problem,
the axles are 28 spline.
find them anywhere
Old 02-27-2008, 04:32 PM
How strong are the 8.2's ? When I bought my car it was a 4 cyl, but I'm in the process of changing to a sbc that will have around 400 HP.
10 bolt or 12 bolt???? tinman386 Transmission - Rearend 14 07-31-2007 03:03 AM
Swaping 10 bolt rear ends, what will fit? fansick Transmission - Rearend 5 07-13-2007 03:41 PM
10 bolt or 12 bolt rearends ? a62chevy Transmission - Rearend 5 09-21-2003 06:16 AM
12 Bolt or 10 Bolt bizkit075 Transmission - Rearend 3 03-03-2003 12:59 PM
converting GM 10 bolt to rear disc brakes, have questions HotRodF100 Suspension - Brakes - Steering 7 09-18-2002 12:22 PM
