10 bolt to 14 bolt gm upgrade - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2007, 09:41 AM
I have replaced my gm 10 bolt with a 14 bolt semi float rear in 96 chev pickup 1/2ton. The u joints are smaller. Do I need a 3/4 ton shaft or have one custom made
Old 12-24-2007, 10:23 AM
You just need a special adapter ujoint. They are available at most parts stores.
Old 12-26-2007, 02:24 AM
HRC HRC is offline
U-Joints
Have run into this a few times a long time ago. My solution was a '76 Ford 4X4 front driveshaft U-joint. One side is wider than the other. Might work for you and I know it's been used on several other applications. I just can remember the Ford because I replaced one and was surprised it was the same one I had used on Chevies. Worth checking out.
questions about swapping R/E gears from a 12 bolt Gm into a Pontiac 10 bolt housing l Bad Rat Transmission - Rearend 6 06-11-2007 11:50 AM
Brakes on GM 14 bolt FF axle 75gmck25 Transmission - Rearend 10 01-27-2007 04:31 PM
gm 10 bolt gmonkey Transmission - Rearend 2 10-20-2003 09:26 PM
gm 10 bolt axle, bearings. hepcat Transmission - Rearend 4 09-20-2003 09:36 AM
7.5" gm 10 bolt????? Vancouver Grand Prix Transmission - Rearend 6 05-27-2003 04:49 PM
