Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 10 bolt and a 454
Old 10-15-2011, 12:34 AM
Pantaz's Avatar
Pantaz Pantaz is offline
I broke 2 different 10-bolts in my '68 GTO with a high mileage, nearly stock 400 (not HO, or SD) and a TH400. Broke a spider gear in the the original "open" differential. Replaced it with a posi unit. Broke the pinion gear shaft on that one. Replace the whole rear end with a junk yard 12-bolt. No more problems.
