Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 10 bolt and a 454
Old 10-15-2011, 03:53 AM
chevykid90's Avatar
chevykid90 chevykid90 is offline
454, what turns your crank?
Last journal entry: Replacing bearings and crank
I have had no issues with my 10 bolt 8.5" behind my 454. The 12 bolt ring gear is only 8.875" so its really not that much bigger than the 8.5" 10 bolt. I have seen many many guys running the 8.5" with no problems. Your rear end is only as good as the parts you put in it. I guess that goes with pretty much anything in hot-rodding tho.
