Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 10-23-2003, 04:49 PM
big455's Avatar
big455 big455 is offline
10 bolt 7.5 to ford nine inch
Hi everyone,
I just got my new ford nine inch from currie enterprises to replace my weak 10 bolt 7.5 inch rear thats in my 83 Regal. I'm sure this swap has been done a thousand times so I was just wondering if anyone knows exactly how much longer the ford is than the GM rear so I know how much to shorten my driveshaft Thanks for any replies.
Old 10-23-2003, 08:33 PM
woodz428's Avatar
woodz428 woodz428 is offline
Arrow re: 10 bolt 7.5 to ford nine inch
There are several different length yokes for the 9", so depending which one you have it will vary. There is a good possibility that all you will have to do is change the rear u-joint (maybe not even that with the right yoke) to one with 2 different cross dimensions ( a conversion joint).
Old 10-23-2003, 09:53 PM
big455's Avatar
that would be great .I've almost got the new rear in and I was hoping to be able to get it on the road for a little bit before the snow flies. I'm going from a 2.56 one wheel wonder to 3.70 posi. I've got 430 HP and I'm really excited to see how much difference a quality rear-end with good gears will make.
Old 10-28-2003, 06:21 AM
big455's Avatar
just got it together and found out that the drive shaft is still the correct length..... YES!!! I found a local shop that will rebalance and put on a conversion U-joint for 100 dollars. one other question, how much horsepower is the stock driveshaft good for if I slap on slicks and go to the drags?
Old 10-28-2003, 07:34 PM
molevolent_creations molevolent_creations is offline
it all depends on how long it is and what its made of..the longer it is the easyer it will snap
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
