10-Bolt 8.2 Gear Swap?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2003, 02:23 PM
Question 10-Bolt 8.2 Gear Swap??
I'm on the verge of swapping ring & pinion gears on my 10-bolt rearend from the stock 2:73 to a 3:55 gear ratio. I was told that the stock carrier will accept up to a 3:08 ratio and I will need to change out the carrier to accept any gears 3:08 and above. Correct or Incorrect???
Thanks....
[ May 22, 2003: Message edited by: chevy2N ]
[ May 23, 2003: Message edited by: chevy2N ]</p>
Old 05-22-2003, 02:25 PM
MI2600's Avatar
Member# 3287
Post
I've got an 8.2 in my '67. I think you can use the same housing but need to change the inside carrier.
