Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 10 bolt Camaro differential with disc brakes
Old 11-28-2012, 12:42 PM
gearheadslife gearheadslife is offline
Banned
Originally Posted by The Chevyman View Post
I have a 57 Coupe with a factory Camaro disc brake rear end I have no idea which model its from and I wish to replace the calipers. Can anybody tell me which models had the rear discs or how to identify this rear end?
my guess, is the rear is a 10 bolt out of a 79-81 2nd gen f body..
as it was leaf spring..
look at the center of the rear end, where the driveshaft is.. on the drivers side of the shaft. if there is a mounting boss. going straight up and down..
if it has this type mount for a torque arm it's from a 82-02
and they had many running changes on the rears of those
the rear in photo is a ford 9" but will give you an idea where the mount for the torque arm is
