10 bolt carrier swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2006, 07:02 AM
i have a 91 camaro with 243 gears and no posi. i also have a 79 ta with 10 bolt 373 posi. my question is will the carrier from the 79 ta swap into the 91 camaro rear end. also wondering if there is anything else that i can do to swap them.
Old 03-05-2006, 02:46 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
The 91 is the GM 7.625 inch, the 7.5 will be a direct swap.
Most likely the 79 has the 8.5 inch, if so, there is no way anything will interchange between the axles.
Old 03-07-2006, 06:41 PM
DOUBLEDICK's Avatar
rearend
If you are happy with your current gear ratio you might want to consider a powertrax locker.I have one in my GM 10 bolt and I love it.I installed it myself in about 2 hours.no special tools required.
Old 03-14-2006, 03:13 PM
If you want gears or anything like that, go to your junk yard and look up s10's/ isuzu rodios/ and other 4x4s and you will have any gear ratio you want.
look and make shure your rear is the same as they are. I got 4.56 gears from a Isuzu 4x4.
10 bolt vs. 12 bolt. Iwanttolearn Transmission - Rearend 4 02-05-2005 10:32 PM
10 bolt question JamesRS Transmission - Rearend 9 02-01-2005 08:52 AM
10 bolt Rear End 71chevelle406 Transmission - Rearend 5 11-10-2003 04:50 PM
10 bolt posi switch? newchevyman Transmission - Rearend 1 11-04-2003 02:10 AM
12 Bolt or 10 Bolt bizkit075 Transmission - Rearend 3 03-03-2003 11:59 AM
