10 bolt gm differential
need to identify my GM 10 bolt #J88 3725899 GM14 has an O on the driver side as well
"J88" is the date code: October or November ("I" wasn't always used) 8th. of a year ending in '8'.
The "3725899" casting number shows up as a '57 Chevy possibly non posi. Does it have a removable center section that comes out the front of the housing? If it does, you should look for stamped (not cast) numbers on the passenger side of the third member. They're often hard to see and will take cleaning the rust and crud to see them. |
The center pig removes and the stamped # A31015 . It is a factory posi also. Thannks
By the date code I'd say it was original to a 1959. The stamped number usually has two letters to it.
More HERE. |
| How to narrow a 10 bolt rear differential? | d-ancer | Transmission - Rearend | 2 | 02-26-2011 03:46 PM |
| Identifying this 12 bolt differential | Johnny406 | Transmission - Rearend | 7 | 10-15-2010 04:45 PM |
| Chevy 10-bolt Differential Identification | Daytona F1 | Transmission - Rearend | 3 | 06-02-2010 07:45 PM |
| 14 bolt 4x4 differential questions | tyson snyder | Transmission - Rearend | 2 | 02-27-2010 08:06 PM |
| GM 10-Bolt Differential Carrier | leejoy | Transmission - Rearend | 4 | 06-14-2008 08:55 PM |
