We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 07-01-2006, 10:21 AM
I_3putt's Avatar
I_3putt I_3putt is offline
10 bolt GM rear end
I have a 56 Chevy with 454 and a TH400 tranny. I had someone put in 4:10 gears and now I have to re-torque them. NAPA and others have no idea what lubricant I need to put in the pumpkin. It is a posi-trac (because someone told me that because it left two tire marks on squeling tires.)
Can anyone help?? THX...
Old 07-01-2006, 01:39 PM
joe350s10's Avatar
joe350s10 joe350s10 is offline
Bigger is better
if it is a posi trac rear end then you will need to add the special posi trac additive with the gear oil. not doing so could burn up the clutches on the posi unit.
NAPA should be able to tell you what gear oil you should fill it with....so maybe try a different NAPA since the guys at your local one don't seem to be able to look it up.
You may aslo want to call your local dealership and see what they suggest.
Old 07-09-2006, 03:43 PM
fast68's Avatar
fast68 fast68 is offline
likes chevy trucks & boobies
chevy dealer parts counter has the limited slip additive its about 8 bucks a bottle
80w90 is what oil to use
you better run the stamping code on the axle tube with the chevy dealer parts counter to make sure its really lim slip
just because it left black marks with both tires doesnt mean much
good luck
Old 07-09-2006, 07:07 PM
Triaged Triaged is offline
Triaged's barnstar
Wiki editor
Last wiki edit: Crankshaft Coalition Wiki
Why would you need to re-torque them If you do pull out each bolt, clean it as well as the threads in the ring gear with brake cleaner, apply red loctite, and then torque it.
Old 07-16-2006, 05:19 PM
Chevy39 Chevy39 is offline
It has been my experience to use fully synthetic oil in the rear end. It cost more, but the gears will last a lot longer. The regular gear oil will foam a lot and will not work as good. I found this out by racing on the dirt track.
Old 07-17-2006, 05:55 PM
KernCountyKid's Avatar
KernCountyKid KernCountyKid is offline
If it aint broke, break it!
If you're running a 56 10 bolt, just clean up the third member and look for a giant letter "P" cast into it. If you don't have that then you don't have posi. You have to have that housing to run the posi. From what I understand they came in 'Vettes, so you'd be lucky to have scored one. Its worth about 550$ on ebay.
Someone correct me if I'm wrong! Dont want to put forth bad info, but this is correct to the best of my knowlege.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "10 bolt GM rear end"
Questions on a GM 14 bolt rear. 1tunda Transmission - Rearend 8 12-26-2008 09:13 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 23 11-21-2008 07:27 PM
Question about 12 bolt rear end Roy_67_SS350 Transmission - Rearend 6 12-14-2003 11:57 AM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
converting GM 10 bolt to rear disc brakes, have questions HotRodF100 Suspension - Brakes - Steering 7 09-18-2002 11:22 AM
