Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 10 bolt GM rear end codes?
Old 01-06-2009, 12:35 PM
303oldskool 303oldskool is offline
1 more for now
Another question would be do you know a site where I could find out exactly from the code what rear end it is and the specs on it ( gear ratio) its a 12 bolt as well and also is the correct number just one letter and than 2 numbers?
the numbers I found are...(D26)(GM72)and(3896339 with the letter N underneath the numbers) Thanks again by all means!!
