Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 10 bolt GM rear end codes?
Old 01-07-2009, 07:07 PM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Differential/Driveline
Originally Posted by 303oldskool
Im not sure really its actually in my K5 and im not finding any numbers any where else I think im just gonna go ahead and pop the rear cover off and go that route for sure? thanks very much for your guys help as well
another ? I had is I have heard of a way of counting the driveshafts rotations when having the rear end jacked up and spinning the rear wheels slowly?
Do you guys know of anything like this? I guess there is some math involved with it to get the correct ratio?
If you do how would I go about doing that?
Then it's definitly not a 66 housing,my bad! If you don't know the history of the diff, it would be a good idea to at least change the oil. I would pull the cover and verify the ratio.
