10 bolt GM rear end codes? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2009, 09:41 AM
WHere can I find the code on a 10 bolt GM rear end and will this code tell me the gear ratio on the inside?
I appriciate any help I can get thanks everyone!!
Old 01-06-2009, 10:10 AM
SSedan64's Avatar
On the passenger side axle tube. Need a wire brush to clean. Look all around it. They're not all in the same place on the tube.>>>>>
http://www.camaros.net/years/69/69rearcodes.html
Scroll up on page.>>
http://www.camaros.org/drivetrain.shtml#AxleCodes
Old 01-06-2009, 11:27 AM
thanks a lot man i appriciate it very much
Old 01-06-2009, 11:35 AM
1 more for now
Another question would be do you know a site where I could find out exactly from the code what rear end it is and the specs on it ( gear ratio) its a 12 bolt as well and also is the correct number just one letter and than 2 numbers?
the numbers I found are...(D26)(GM72)and(3896339 with the letter N underneath the numbers) Thanks again by all means!!
Old 01-06-2009, 07:29 PM
SSedan64's Avatar
Those look like the #'s off the center section. What does the rear cover look like? Round for a car or Pear/Apple shaped for a truck?
D-2-6= April 2nd 1966
3896339 = casting #??
GM72 = nothing important
The Axle code is on the passenger side front of tube, will be 2 letters, #'s & a letter. Something like this CX 0727 B >>
ProStreet6t9 may know what casting # that is.
ID:	35441   Click image for larger version
Old 01-06-2009, 09:00 PM
The ratio code is usually two letters (sometimes 3, sometimes a number & 2 letters), and is found on the right-hand axle tube. The code will tell you what was originally installed in the housing, but nothing about any changes that might have been made since then.
You'd be better off checking the true ratio either manually, or by popping the cover and looking on the edge of the ring gear for four sets of numbers, two of which are tooth counts and two of which are date codes.
Old 01-07-2009, 10:11 AM
prostreet6t9's Avatar
Differential/Driveline
I looked for that cast number and I'm not having any luck YET, It is a 12 bolt car correct? Did you find any other numbers on the axle tube?
Are you just wanting the Ratio or Wanting to know what the housing came out of originally?
Old 01-07-2009, 11:15 AM
Double check that casting number to make sure it's correct, I think the D26 is for a 1966 housing as SSedan stated. I cant find any 66 12 bolt car's with that casting number.
Old 01-07-2009, 05:11 PM
Im not sure really its actually in my K5 and im not finding any numbers any where else I think im just gonna go ahead and pop the rear cover off and go that route for sure? thanks very much for your guys help as well
another ? I had is I have heard of a way of counting the driveshafts rotations when having the rear end jacked up and spinning the rear wheels slowly?
Do you guys know of anything like this? I guess there is some math involved with it to get the correct ratio?
If you do how would I go about doing that?
Old 01-07-2009, 06:07 PM
Then it's definitly not a 66 housing,my bad! If you don't know the history of the diff, it would be a good idea to at least change the oil. I would pull the cover and verify the ratio.
Old 10-03-2012, 08:23 PM
countryboy5388's Avatar
Look in your glove box there should be a tag with several codes on it there should one that is gu and a number that will be the gear code
Old 10-04-2012, 05:57 AM
big gear head's Avatar
High Performance Rear Ends
Look at the date on this thread! It's almost 4 years old!
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Questions on a GM 14 bolt rear. 1tunda Transmission - Rearend 8 12-26-2008 09:13 PM
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 09:03 AM
79 TA, 10 Bolt rear end, highway gears, looking to step up Gladis Transmission - Rearend 3 04-03-2007 08:19 PM
converting GM 10 bolt to rear disc brakes, have questions HotRodF100 Suspension - Brakes - Steering 7 09-18-2002 11:22 AM
