10-bolt GM w/4:10 gears and an Eaton posi: pops & snaps - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2012, 04:27 PM
I've got a 10-bolt GM with 4:10 gears and an Eaton posi unit. It has 35 spline axles. All supposedly in good condition. I have a receipt for a total rebuild (all the parts mentioned) from a reputable shop but they're no help. It has the additive specifically for posi units.
I just got the car on the road about a month ago. What's happening is that when I take it out, it starts off fine, but after driving around for a while I can hear loud snapping or grabbing and releasing sounds coming from the rear end. It's loud and nothing like the sounds some posi's make when turning.
It starts after about 45 minutes of easy city driving and sounds like it's not going to hold together much longer. It's very noticeable. I can hear it best when backing up or turning. But it only does it after driving it a bit. Even with the noises, it seems to run fine.
If it's worn out or broken why doesn't it make noises from the very get go. I can't see the gear oil breaking down but....heck, I don't know. Money's short right now and I don't want to take it in to a shop. I want to sell the car but I can't sell it like this. New posi in my future?
But shouldn't mine make noise all the time and have some symptoms of not working well? Somebody please school this boy.............
Old 11-25-2012, 04:32 PM
gearheadslife's Avatar
MentalMuffinMan
eaton posi with 35 spline?
Old 11-25-2012, 04:42 PM
What's going on?
Well why not just tell me. I don't know. I know many things you don't. Tell me the problem so I can fix it. Sheesh.
Old 11-25-2012, 04:43 PM
poncho62's Avatar
Wiki Edits: 5
Probably is the posi unit making noise...Take the cover off and have a look at it.......I would change the gear oil, put a good quality posi fluid in it.....If it still makes noise, then off to a shop
Ontario Rodders
Old 11-25-2012, 05:02 PM
prostreet6t9's Avatar
Differential/Driveline
Grab ya a couple bottles of the ford motorsports additive Part#43161.
Sounds like the posi is chattering.
Your posi is a 28 or 30 spline. But either way put some additive in it and do some figure eight's to get it worked in.
Old 11-25-2012, 05:05 PM
big gear head's Avatar
High Performance Rear Ends
You don't have 35 spline axles. At most you have 30 splines. You can get 35 spline axles with a spool, but the 8.5 10 bolt Eaton Posi is either 28 or 30 spline.
Change the oil. Use a good brand name 80W90 gear oil and a bottle of GM or Ford limited slip oil additive. Drive it around for a while and it should get better as you drive. While you have the cover off check for anything that doesn't look right, especially pieces in the bottom of the housing.
Old 11-25-2012, 05:12 PM
MentalMuffinMan
Sir, we need correct info, to be able to HELP you..
Old 11-25-2012, 05:34 PM
Really don't matter what the spline count is. All the Eaton posi's are built the same but just have different side gears.
Old 11-25-2012, 05:43 PM
vinniekq2's Avatar
when my 12 bolt chattered real bad,we took out the clutches and shims and shuffled them and putit back together without the rat trap.We used 2 bottles of additive. if you take it apart,take a real close look at the spider gears
Old 11-25-2012, 06:01 PM
[QUOTE=Born Too Loose;1615745].
That statement is a common complaint with a new posi and chattering.
What brand of oil and additive did you use?
Old 11-25-2012, 08:21 PM
OK thanks guys. I bought the gear oil and additive at a NAPA store. Can't remember the names. I'll pull the cover and see what shakes then refill it and do some figure 8's. Been riding stroker Harleys most of my life (I'm 66). Them, I know. Cages? Not so much. Thanks again and Peace.
Old 11-25-2012, 11:09 PM
MentalMuffinMan
ya it does... 35 spline could be a locker or spool.. giving info "thinking its a eaton posi" won't help much..
Old 11-26-2012, 05:58 AM
If you bought the oil additive at a auto parts store then that is where your problem is. Only the GM and Ford (possibly Chrysler too) additives work. The junk that the auto parts stores sell is no good.
Old 11-26-2012, 08:17 PM
"I've got a 10-bolt GM with 4:10 gears and an Eaton posi unit. It has 35 spline axles.
I don't see the word "thinking" lol
Needless to say I'm sure it will fix the Op's problem with the info he gave.
Eaton posi 8.2 10 bolt? defilade Transmission - Rearend 1 12-12-2011 11:26 PM
GM Eaton 10 Bolt Posi (good Kind Needs spiders) sjkonyndyk Transmission - Rearend 2 12-06-2010 09:38 AM
10 bolt posi Auburn vs Eaton sanman Transmission - Rearend 3 04-30-2008 08:04 AM
Will open ended gears work on an eaton posi unit? batman09 Engine 5 01-01-2005 06:26 AM
Who has the best prices online for an eaton posi and gears? batman09 Engine 4 12-30-2004 08:57 AM
