10 Bolt Id - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2007, 09:42 PM
10 Bolt Id
I Purchased A 10 Bolt From A Junk Yard For A 71 Chevelle. The Measurements Are The Same As The 8.2 That Was In The Car, I Was Needing An 8.5. Stampings On The Right Axle Tube Are "sa B159 1". On The Pumpkin Front Bottom "cfd". On The Pumpkin Top And The Front Of The Axle Tube Openings A Large "a". Also On The Pumpkin "1235197" There Was One Brake Drum On The Axle That Had A Buick Insignia. What Have I Bought And Will A Standard Gm 8.5 Ring And Pinion Work, The Pinion Dia Is 1.625 And Has Bolt In Axles. It Bolted Right In As Far As The Four Link When We Checked It For Fit. Can Anyone Tell Me What This Is Out Of? And If There Is A Problem As Far As Building And Using It?
Old 07-25-2007, 09:33 PM
See if this site has what you need: http://www.oldsmobility.com/10bolt-tech.htm
Old 07-27-2007, 12:51 PM
I have already checked that site, and while they have the most info i've found, i couldn't really make an i.d. thanks for the reply and suggestion, but i guess i'll just keep looking. i did have one parts guy say that the stamping on the axle tube indicated that the "SA" was for the gear ratio, that the "B" was for Buick, and that the "159" inndicated 159th day of year, and that the "1" indicated first shift, but could not tell me how to identify year or application.
thanks very much for your reply, i appreciate the input.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Swaping 10 bolt rear ends, what will fit? fansick Transmission - Rearend 5 07-13-2007 02:41 PM
10 bolt or 12 bolt rearends ? a62chevy Transmission - Rearend 5 09-21-2003 05:16 AM
12 Bolt or 10 Bolt bizkit075 Transmission - Rearend 3 03-03-2003 11:59 AM
converting GM 10 bolt to rear disc brakes, have questions HotRodF100 Suspension - Brakes - Steering 7 09-18-2002 11:22 AM
