10 bolt identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2006, 01:32 PM
I picked up a GM 10 bolt and I think it is an 8.2. The numbers on the axle read CRW0152 I would like some help identifying the year, would like to rebuild seeing it was free. Also there was no carrier or ring and pinion just the housing and some casting numbers on bottom right looking from the rear A41, top left same direction 12345, bottom left 67890. Looking from front bottom right GM75, left 3969340NF.Any help would appreciated.
Thanks Paul51
Old 04-04-2006, 03:58 PM
sicksixseven's Avatar
Ground Clearance Is Over-Rated
Not to pee in your cherrios here, but a 10 bolt minus carrier, R&P and other stuff is worth its wieght in scrap and thats about it. A 10 bolt isnt really all that strong, and you might not be too pleased with the results if you spend time and money to rebuild it. It really depends on what you want to do with it. If it were a 12 bolt, thats a different story, but a 10 bolt is a 6 cylender rear end.
Old 04-04-2006, 05:21 PM
Thanks for the reply, but if its free its for me and if you seen what they are asking for these at swap meets you can understand what I mean. It will cost me around 600 to rebuild, just wanted to know what year do you know?
Old 04-04-2006, 05:42 PM
If it's an 8.5 you can make a really strong differential out of it. Ive heard of people bending 12 bolt axle tubes and going back to 8.5s without fail. I don't want to start that conversation again. 12 bolts are usually stronger. But 8.5s are comparable.
I had an 68 camaro with an 8.2 rear end and a 300hp+ V8 engine and like 285 tires. No problems for years. POINT IS- Ten bolts are not weak.
10 bolt to 14 bolt rear-end conversion in 96 1/2 ton chevy 4X4??? tommytempest Transmission - Rearend 14 05-09-2007 09:19 PM
68 Camaro 10 bolt & 2000 truck limited slip 68CaliCamaro Transmission - Rearend 6 12-22-2003 05:57 PM
GM 8.5", 7.5" 10 bolt ?? and 700R4 ?? williemon Transmission - Rearend 4 12-16-2003 04:11 PM
10 bolt or 12 bolt rearends ? a62chevy Transmission - Rearend 5 09-21-2003 06:16 AM
12 Bolt or 10 Bolt bizkit075 Transmission - Rearend 3 03-03-2003 12:59 PM
