10 Bolt main identification - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-16-2012, 06:14 PM
  #17 (permalink)
Old 07-16-2012, 06:15 PM
  #18 (permalink)
Old 07-16-2012, 07:34 PM
big gear head's Avatar
High Performance Rear Ends
It's the 8.5 10 bolt, which means it's not a first gen Camaro rear end. The 8.5 wasn't put into production until '71. It could be a second gen Camaro rear end, which would make it 61 inches wide. If it is 60 inches wide then it's a '72 or later Nova, Omega, Ventura or Apolo rear end.
  #19 (permalink)
Old 07-17-2012, 02:27 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by redtoptravis View Post
Ok finally got here and measured. 60 inches. its a 8.2 i guess then.
Had you gone to the link I provided you back at post #3 you'd have easily seen it was a 8.5 corporate 10-bolt.
The limited info I have shows the rear ratio to have originally been a 2.56, and from a '72 X-body. If it's still got the original diff, it's a 2-series carrier and cannot use 2.73-up gears unless a spacer is used (which I wouldn't recommend). You will probably find it's an open diff anyway.
  #20 (permalink)
Old 07-17-2012, 09:19 AM
Yes it is an open. I'm thinking for now this diff will work but I'll upgrade when I drop the 450 hp motor in. I will look up what an X body is and see if I can put together brakes for this rear. I can not afford to drop cash on the disk setups. I may hit up a junk yard and just get a full brake set from them to through on. I'm gonna post a question in the Brake section now to find out what manual brakes I can put on this so I can retain the remaining orriginal brakes on this car.
  #21 (permalink)
Old 07-17-2012, 11:18 AM
X body is Nova, Omega, Ventura or Apolo. Any brakes from a '65 to '77 Chevy car except full size will work. You can also use brakes from a later S10 truck as long as it has the 4 bolt backing plates.
10 bolt, f body, rear end, rear end identification
Chevy 350 2 bolt main or 4 bolt main? daledouglas Engine 5 07-21-2011 05:10 PM
350 bolt 4 bolt main 6-71 blown. vcb Engine 30 06-02-2010 07:46 AM
2 bolt vs 4 bolt main 350 small block CanadianCory Engine 9 10-30-2005 09:31 PM
2-bolt main vs. 4-bolt main chevy hause Engine 5 10-26-2005 01:37 PM
What main cap girdle would you recommend for a chev 400 with a 2 bolt main stonedchihuahua Engine 19 01-05-2003 05:31 AM
