10 Bolt main identification
Here is what I have found. ID stamped on the tube is (T or L)AC 57 2402
on the pumpkin is H (O or 8 or 6)20 I was told Camero. it is going into my 54 Chev and I need to get brakes for this but I dont know what year camero to buy them for and any other info I will need. How do I find out a ratio? and Is this a C clip rear? I will need to pull the axles out if i need to change the backing plates. Can I put the orriginal 54 drum brakes, backing plate and all on this rear? Thank you for the help!!! Travis, PA |
When I recieved this axle it had only bacing plates and no spring perches. Where am I measuring for the 60"s since the drumbs are missing? Withour knowing what vehicle this rear came from how can I come up with brakes for this rear on a budget? I realize I can get a disc conversion but they are costly. Is there a jumk yard set up that I can use my already installed backing plates? Or a cheap set up I can put together at the parts store that will fit the existing backing plate on my rear. |
Axle flange to axle flange, where the wheels bolt on, should be 60 inches for a first gen Camaro. The first gen Camaro brakes are the same as all 8.2 10 bolt, 12 bolt and 8.5 10 bolt Chevy brakes up into the late '70s. You can't use the '54 brakes because the housing ends are different and they will not bolt on.
That makes sence. Thank you
Axle hang out on the Camaro rear end will be 2.75 inches. I don't know what the truck axle hang out is, but if it doesn't match then the brakes will still not work. This would have to be measured before going any farther.
Got it, thanks.
The nut was 1 1/4"
| Tags |
| 10 bolt, f body, rear end, rear end identification |
| Chevy 350 2 bolt main or 4 bolt main? | daledouglas | Engine | 5 | 07-21-2011 05:10 PM |
| 350 bolt 4 bolt main 6-71 blown. | vcb | Engine | 30 | 06-02-2010 07:46 AM |
| 2 bolt vs 4 bolt main 350 small block | CanadianCory | Engine | 9 | 10-30-2005 09:31 PM |
| 2-bolt main vs. 4-bolt main chevy | hause | Engine | 5 | 10-26-2005 01:37 PM |
| What main cap girdle would you recommend for a chev 400 with a 2 bolt main | stonedchihuahua | Engine | 19 | 01-05-2003 05:31 AM |
