-   -   10 bolt posi (http://www.hotrodders.com/forum/10-bolt-posi-10196.html)
67rscamaro 02-21-2003 07:00 PM
10 bolt posi
ok i wanna put a 1970's style chevy posi into a 67 camaro with mono leaf. what i was told to fit it in their is to cut off the brackets and buy some 67 camaro ones and reweld them into the correct place for 67. will this work i need info asap pleasee i can get it cheap if i buy it now. thank you very much :eek:
70 nova 02-21-2003 09:32 PM
what did the 70 chevy rear end come out off if acar go for it. If it came out of a truck. I Thank, It will be to wide. Just my opinion.
67rscamaro 02-21-2003 10:34 PM
it is a 1/2 inch from backing plate to backing plate wider
bigblock67cam 02-22-2003 10:40 AM
What kind of rearend?
67rscamaro 02-23-2003 10:27 PM
this is a 70's camaro rearend its a 10 bolt posi
engines 02-24-2003 01:35 PM
What size is it 7.5 ? I need a posi for my 72 camaro ss 4 speed model it has a 10 bolt non posi. Is a 69 the same width as a 67? Can you just change the carrier from your 70 to the 67?Best of luck.
67rscamaro 02-24-2003 05:13 PM
i dont know what 7.5 is what do u measure for that. and i do believe 67 68 69 are the same
67rscamaro 02-24-2003 08:31 PM
will the floating axle mounts work for my problem? :p
67rscamaro 02-24-2003 08:35 PM
floating housing mount sorry
skippasco 02-25-2003 05:37 PM
[quote]Originally posted by 67rscamaro:
<strong>ok i wanna put a 1970's style chevy posi into a 67 camaro with mono leaf. what i was told to fit it in their is to cut off the brackets and buy some 67 camaro ones and reweld them into the correct place for 67. will this work i need info asap pleasee i can get it cheap if i buy it now. thank you very much :eek: </strong><hr></blockquote>
mmetalman 02-26-2003 12:39 AM
Just measure the mounting pads on both diffs to be sure the are spaced right, if not, move them (cut&weld) to the correct place. Cars never have floating axles, I've only ever seen them on large trucks, min 3/4ton.
kurley 02-26-2003 09:28 AM
Me and my wife have a 69 camaro.I replaced the stock 8.2 rear end with a 8.5 out of a 74 nova with 373 posi. It fit fine.The first thing you need to check is the width from backing plate to backing plate.You might have to change the spring perches.What size rear end do you have if it's smaller than a 8.2 i wouldn't mess with it, if you have a motor with horse power.A 8.5 will withstand about 500 horsepower.
TurboS10 02-26-2003 03:40 PM
I think you will be fine on the width. The 7.5 is in reference to the ring gear diameter. The larger 8.5 is much stronger. You can basically just measure to see what it is.
Chris
67rscamaro 02-26-2003 08:11 PM
ok i am going to provide a link to show everybody if u dont allready know what the floating housing mounts are http://www.jegs.com/cgi-bin/ncommerc...56&prmenbr=361 and if those wont work where can i order the original 67 housing mounts?
TurboS10 02-27-2003 07:30 AM
<strong>ok i am going to provide a link to show everybody if u dont allready know what the floating housing mounts are http://www.jegs.com/cgi-bin/ncommerc...56&prmenbr=361 and if those wont work where can i order the original 67 housing mounts?</strong><hr></blockquote>
Oh yeah, I forgot to say something about that. Housing floaters are designed for use with ladder bars and leaf springs. With ladder bars, the axle has a diffferent plane of travel than with the original leaf springs. The floaters allow the axle to use the ladder bar travel plane and the springs to support the wieght of the car.
They will not work for what you are doing unless you want to install ladder bars.
Chris
