10 bolt posi - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2003, 06:00 PM
New Member
Smile 10 bolt posi
ok i wanna put a 1970's style chevy posi into a 67 camaro with mono leaf. what i was told to fit it in their is to cut off the brackets and buy some 67 camaro ones and reweld them into the correct place for 67. will this work i need info asap pleasee i can get it cheap if i buy it now. thank you very much
Old 02-21-2003, 08:32 PM
Post
what did the 70 chevy rear end come out off if acar go for it. If it came out of a truck. I Thank, It will be to wide. Just my opinion.
Old 02-21-2003, 09:34 PM
New Member
Post
it is a 1/2 inch from backing plate to backing plate wider
Old 02-22-2003, 09:40 AM
Post
What kind of rearend?
Old 02-23-2003, 09:27 PM
New Member
Post
this is a 70's camaro rearend its a 10 bolt posi
Old 02-24-2003, 12:35 PM
Thumbs up
What size is it 7.5 ? I need a posi for my 72 camaro ss 4 speed model it has a 10 bolt non posi. Is a 69 the same width as a 67? Can you just change the carrier from your 70 to the 67?Best of luck.
Old 02-24-2003, 04:13 PM
New Member
Post
i dont know what 7.5 is what do u measure for that. and i do believe 67 68 69 are the same
Old 02-24-2003, 07:31 PM
New Member
Post
will the floating axle mounts work for my problem? :p
Old 02-24-2003, 07:35 PM
New Member
Post
floating housing mount sorry
Old 02-25-2003, 04:37 PM
Post
[quote]Originally posted by 67rscamaro:
<strong>ok i wanna put a 1970's style chevy posi into a 67 camaro with mono leaf. what i was told to fit it in their is to cut off the brackets and buy some 67 camaro ones and reweld them into the correct place for 67. will this work i need info asap pleasee i can get it cheap if i buy it now. thank you very much </strong><hr></blockquote>
Old 02-25-2003, 11:39 PM
Post
Just measure the mounting pads on both diffs to be sure the are spaced right, if not, move them (cut&weld) to the correct place. Cars never have floating axles, I've only ever seen them on large trucks, min 3/4ton.
Old 02-26-2003, 08:28 AM
Post
Me and my wife have a 69 camaro.I replaced the stock 8.2 rear end with a 8.5 out of a 74 nova with 373 posi. It fit fine.The first thing you need to check is the width from backing plate to backing plate.You might have to change the spring perches.What size rear end do you have if it's smaller than a 8.2 i wouldn't mess with it, if you have a motor with horse power.A 8.5 will withstand about 500 horsepower.
Old 02-26-2003, 02:40 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
I think you will be fine on the width. The 7.5 is in reference to the ring gear diameter. The larger 8.5 is much stronger. You can basically just measure to see what it is.
Chris
Old 02-26-2003, 07:11 PM
New Member
Post
ok i am going to provide a link to show everybody if u dont allready know what the floating housing mounts are http://www.jegs.com/cgi-bin/ncommerc...56&prmenbr=361 and if those wont work where can i order the original 67 housing mounts?
Old 02-27-2003, 06:30 AM
TurboS10's Avatar
Wiki Edits: 2
Post
<strong>ok i am going to provide a link to show everybody if u dont allready know what the floating housing mounts are http://www.jegs.com/cgi-bin/ncommerc...56&prmenbr=361 and if those wont work where can i order the original 67 housing mounts?</strong><hr></blockquote>
Oh yeah, I forgot to say something about that. Housing floaters are designed for use with ladder bars and leaf springs. With ladder bars, the axle has a diffferent plane of travel than with the original leaf springs. The floaters allow the axle to use the ladder bar travel plane and the springs to support the wieght of the car.
They will not work for what you are doing unless you want to install ladder bars.
Chris
