Hang on to your wallet, I mean hat!! You are talking $1000 +or - a few.
Trees |
The 8.5 that GM started using in the early 70's is a corporate rearend, GM used these rearends in all A-bodies and they all have the C-clip axles. The 8.2's was where you got into the difference between Chevy Rearends and those used in B-O-P applications.
Thanks for the replies guys.
Can anyone tell me what gear ratio this rear end has by the code from the axle tube??? SBB0531 I can't find anything to tell me what the first to letters "SB" for gear ratio are??? The third letter "B" from what I can find is for Buick. My big problem is what gear ratio is in this rear end??? Thanks, 406chevelle |
i'll buy that from ya 406
if your wantin to get rid of it, im alwas here waitin, i have a 65 lemans it would fit nice on.
I don't know about how to track down the codes on the housing right now but I like to pull the rear cover and see what numbers are on the ring gear, i.e. 36-10, 40-11 to see exactly what gear is in it because there is always a chance the gears could have been changed.
Ok guys stop messing around I know one of you rear end guru's knows the gear ratio for this axle code SBB0531 come on just tell me, LOL
Thanks for the responses, I can't pull the cover off, because it is about 60 miles away, was kinda hope I could find out what gears it has before I drive out there. 406chevelle |
406 -
The only mention I can find of an SB code on a GM rear axle is for Oldsmobile, 1965-1969 (higher?), and it meant 2.78 ratio posi. Could be a BOP 8.2-inch rear?? Eric I looked through both the 65-69 and 70-75 Chevrolet by the Numbers, and didn't see anything close to an SB code rear on the Bowtie side of the house. I looked through both the 65-69 and 70-75 Chevrolet by the Numbers, and didn't see anything close to an SB code rear on the Bowtie side of the house. |
