http://www.astrosafari.com/images/re...Install017.jpg if so its a gov loc, that could be your answer |
no its the clutch eaton style one, im thinkin its bad clutches/frictions cause they only slip when you turn right? or the spider gear becouse the those gears themselfs only spin when you turn right?
yes, I used a "cheaper" MAG 1 stuff with the posi additive already in it Dont think it makes much of a difference which company or if its already mixed? Do I need a seperate bottle of the posi stuff? I also only added 2 quarts that seemed to fill it all the way, perhaps alittle more could be added when i stick my finger in the whole. wasnt sure of the capacity, not sure if that matters.
always add more additive
Shane |
alright ill change it out and see
quick Q - I heard that a old racer trick was to use regular stuff and leave out the additive, that way it would slip less and give it more of a bit...any truth to that |
you dont have to drain it out just suck out 4 oz with a hose and put in a 4 oz thing of possitraction additive.............sometimes theyll bite more in the form of not disengaging and sometimes they wont engage
Shane |
| Will a 12 bolt fit in a 10 bolt? | Malibu73 | Transmission - Rearend | 2 | 05-30-2006 05:50 AM |
| 10 bolt to 12 bolt | 1980Impala | Transmission - Rearend | 8 | 04-25-2004 04:48 PM |
| 10 bolt or 12 bolt rearends ? | a62chevy | Transmission - Rearend | 5 | 09-21-2003 05:16 AM |
| 10 bolt ring & pinion | waynedawg | Transmission - Rearend | 1 | 07-20-2003 07:59 AM |
| What posi in my 12 bolt. | Ed ke6bnl | Transmission - Rearend | 1 | 04-23-2003 06:21 PM |
