10 bolt question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2005, 09:33 AM
JamesRS's Avatar
10 bolt question
I need help identifying a 10 bolt that I pulled out of a 72 Buick Skylark. It has the round pumpkin with the arch's or "scallops" at 3 and 9 o' clock. It also has the ears or squared of tabs at 7 and 5 o'clock.
Because of the squared off tabs, I think it's a 8.5" 10 bolt, but I'm not sure. (I don't have the chance to open it up for a while)
Old 01-26-2005, 10:39 AM
Assuming the diff is the original one from GM, it probably is an 8.5" unit. If you remove the pinion yoke and count its splines you will know. 30 splines = 8.5" 10 bolt
Old 01-28-2005, 07:21 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
1971 Through 1975 Skylarks were equipped with the 8.5 inch.
Old 01-29-2005, 10:58 PM
JamesRS's Avatar
Thanks M&M, do you know if they were 28 or 30 spline axels?
Old 01-30-2005, 03:40 PM
Littlered wagon's Avatar
New Member
If you get the Summit Racing catalog richmond gear has a good guide.
Old 01-30-2005, 06:07 PM
greywulf's Avatar
Real Trucks have Bowties
10 bolt identification
JamesRS ....check these links out to see if they help http://www.wallaceracing.com/carrier-id.html
http://www.novaresource.org/axle.htm
http://www.nastyz28.com/2gcog/rearaxle.html
Greywulf
Old 01-30-2005, 10:47 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
28 spline. They didn't start making them with 30 spline axles until around 1988.
Old 01-31-2005, 08:35 AM
JamesRS's Avatar
Thanks all
Old 02-01-2005, 12:37 AM
I thought the ones with the scallops at 3 & 9:00 were 8.25".
Old 02-01-2005, 08:52 AM
JamesRS's Avatar
This particular unit has both the scallops that the 8.25's have and the tabs that the 8.5's have. That was what confused me. I have had two boards now tell me that this rear is 8.5".
