10 Bolt question - remove axles - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2008, 01:02 AM
85camarojunkie's Avatar
I have a 85 camaro 10 bolt 3.08. I was needing to take my axles out to put new disc brake brackets on. BUT the bolt that holds the slider pin in, wont turn i put a 5/16 BOX end of the wrench on it, Its not rounded off yet but the wrench just spins. Is this a special bolt or do i need a different tool. I cant fit a socket on there, theres not enough room for a ratchet. Has anyone had a problem with this. ........ THANKS in advance
Old 01-13-2008, 09:40 AM
Vortech 4.3's Avatar
jack of all trades
you need a "good" 6 point wrench.... make sure you can move the spider pin, it should move just a little. take a hammer and bang on the carrier right by the retaining bolt, this will help loosen it up.
Old 01-13-2008, 02:22 PM
OK I fugured thats what was wrong. I have about 6k in snap on tools and only have 12 point and sockets, thats the only thing i didnt get lol... So it is a 5/16 correct
Old 01-13-2008, 03:13 PM
jack of all trades
5/16 8mm. i have getten a socket on them.
Old 01-13-2008, 08:33 PM
Bumpstick's Avatar
Hammer and a torch
Use a 1/4 inch drive socket and 2 inch extenstion and a good 1/4 inch ratchet or breaker bar and tap it with a shop hammer... From the factory the bolts have loctite on them...
Be sure to position the carrier at a point level with the centerline of the axles so you can get the socket setup on it... Be sure to use a 6 point socket too...
Old 01-13-2008, 11:54 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
get a little tiny 1/4" drive breaker bar and use a 6 point socket on it.
Chevy 10 bolt front end question Magikal Transmission - Rearend 1 12-09-2007 02:00 PM
gm 8.5" 10 bolt question Rough-Rider Transmission - Rearend 2 03-23-2007 09:31 PM
10 bolt axle questions ChevelleGuy Transmission - Rearend 2 06-17-2004 01:08 PM
10 bolt to 12 bolt 1980Impala Transmission - Rearend 8 04-25-2004 05:48 PM
Basic 10 bolt question Madd Syntst Transmission - Rearend 6 07-08-2002 07:46 PM
