10 bolt rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2001, 10:54 PM
Question 10 bolt rear
I have a 1974 GTO with a 455, a turbo 400/2500 stall,and an 8.5 10 bolt w/3.42-gear
My problem is I ruined a U-joint twice and then the yoke on the rear end. Does anybody know what junkyard cars might have the same yoke untill I order a custum made one? I wouldn't mind using a special U-joint if neccessary.Thanks,
[ October 09, 2001: Message edited by: KBmech ]
Old 10-10-2001, 06:16 PM
Tom Tom is offline
Post
most GM cars will have the same yoke on the 8.5 rear and any junkyard should have many but the real question is why are you going through so many driveline parts? a custom yoke should be unnessesary. if this keeps happening maybe you should try a constant velocity joint from a caddy or large buick/olds but this will require shortening the driveshaft another thing you might try is rebalencing the driveshaft
