10 bolt rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2013, 09:28 AM
37 ford
10 bolt rear end
How do you extract a broken pin bolt in a GM 10 bolt rear end
Old 03-31-2013, 10:56 AM
1971BB427's Avatar
With one of these kits:
Broken Cross Pin Bolt Removal Tool GM 8.2 8.5 8.6 Ford 7.5 8.8 [TLSBCSBR] - $35.99 : JTs Parts & Accessories, Justdifferentials.com
The Following User Says Thank You to 1971BB427 For This Useful Post:
iarednek (04-01-2013)
Old 03-31-2013, 01:09 PM
Is the big pin still iun the rearend?
If it is, I use a small cutoff disc and remove metal until I can turn the broken off poice with a small pic.
Quite often those pins get re-installed by mechanics WAY TOO TIGHT. Then you end up with the issue you are experiencing.
Good luck.
peace
Hog
The Following User Says Thank You to Hogg For This Useful Post:
Old 03-31-2013, 01:18 PM
You can take the carriers caps off and pull the diff out a little to get more working room.
If there are any threads left at all on the bolt, you can often turn it out with a sharp pick tool.
If all threads are gone, the most straightforward method is to grind the end of the pin until you can push the remaining bolt out. You can also drill a small hole in the diff case to enter the hole where the end of the bolt is located on the opposite side of the pin threaded end and then use air pressure to pus the the bolt out.
The Following User Says Thank You to lmsport For This Useful Post:
Old 03-31-2013, 04:09 PM
This is how I did it, but I used a hardened drill bit. You can also use a small grinding stone if necessary. You definitely get the idea that this is a common problem because my local GM dealer had the new cross pin and bolt on the shelf for a 22 year old car!
Simply rotate the carrier until the end of the pin with the bolt is at the best position for working on it. The problem isn't overtightening, the problem is that the hole in the cross pin is much larger than the bolt. Vibration causes it to rotate back and forth in the carrier and bang on the bolt, causing it to fracture eventually.
The Following User Says Thank You to joe_padavano For This Useful Post:
Old 03-31-2013, 07:43 PM
big gear head's Avatar
High Performance Rear Ends
Broken Pinion Shaft Bolt - NastyZ28.com
Read this.
The Following 2 Users Say Thank You to big gear head For This Useful Post:
64nailhead (04-02-2013), iarednek (04-01-2013)
Gm 12 bolt truck rear end vs. car rear end '54 Pontiac Transmission - Rearend 6 02-05-2009 05:17 PM
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 02:25 PM
10 bolt to 14 bolt rear-end conversion in 96 1/2 ton chevy 4X4??? tommytempest Transmission - Rearend 14 05-09-2007 08:19 PM
10 bolt GM rear end I_3putt Transmission - Rearend 5 07-17-2006 05:55 PM
Rear End - 5 bolt axle shafts into 6 bolt rear axle??? Blue Chevy Transmission - Rearend 0 06-07-2002 05:23 PM
