10 bolt rear end chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2006, 06:35 PM
mkn mkn is offline
how can you tell what rear end you have ?
Old 10-01-2006, 06:42 PM
GM counts the bolts that holds the ring gear to the carrier(but somtimes the bolts that hold the diff cover on, such as a 14 bolt), Ford measures the diameter of the ring gear
Brendan
Old 10-01-2006, 08:58 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
They haven't done that since the early to mid 70's.
Pretty much since the day the last 8.2 inch 10-bolt ring gear went into any GM car, they standardized things a bunch more.
Some cars in the 60's and 70's came with one of two and more rarely three diferent axles, like the early Chevelles, you had a choice of either the 8.2 inch 10-bolt or the 8.875 inch 12-bolt, and any reliable book on those cars will tell you the SS was NOT automatically equipped with the 12-bolt either.
That was just as much an option as the stripes were, the SS Chevrolets WERE able to be had WITHOUT the stripes.
Old 10-01-2006, 09:22 PM
Here's a good site for rear-end info. It's primarily for Novas but should apply to many GM rear axles.
NovaResource
Old 10-01-2006, 09:50 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Here are a few more sites you may want to check out:
http://www.hotrod.com/techarticles/axle_rear_end_guide/
http://www.hotrodders.com/kb/browselinks.php?c=57
http://www.g-body.org/tnt/diffs/diff-codes.php
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 10-01-2006, 11:59 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Don't necessarily use the number of bolts on the diff cover to tell what axle you have. I have an oddball 12-bolt-carrier axle in a 73 wagon with 10 diff cover bolts. The shape of the diff is 12-bolt-ish, but its a weird axle... it has an 8.75" ring gear and some other weird things about it.
There was a 10-bolt axle that had 12 bolts on the cover, and there is also a 10-bolt with 9 bolts on the cover.
Try here as well:
http://truckparts-specialists.com/ca...ture-guide.htm
Old 10-02-2006, 10:43 PM
http://www.oldsmobility.com/10bolt-tech.htm
Old 10-08-2006, 09:38 AM
LordMaximo's Avatar
Last journal entry: Painting
Try here as well:
Worst of this situation that is a very common over-looked point, is the series of that third member. In the series issue, you only have 3 or 4 upgrades that can be done to that particular rear drive. You are limited to which rear combination can actually fit in your housing. This was the biggest money factor in the style off the showroom floor when autos are ordered to your likes. Just because you have a certain axle set up, does not mean you have a great deal of combinations for your performance needs.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 09:03 AM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
10 bolt posi 8.5" rear end 406chevelle Transmission - Rearend 7 02-23-2004 09:51 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
